I’m calculating uptime for AWS ALB Target Groups in Grafana using CloudWatch.
My logic is:
NoData after the target group exists → downtime
(this is intentional and required for SLA)
Example query:
FILL(
SEARCH(
'{"AWS/ApplicationELB","LoadBalancer","TargetGroup"}
MetricName="HealthyHostCount"
"LoadBalancer"="${loadbalancer}"',
'Minimum',
$__period_auto
0
This works correctly once the service exists.
The open question
How to correctly handle NoData before the target group existed?
I see two acceptable options:
Option 1
NoData before the target group existed → ignored
Option 2
Do not show or evaluate any data before a fixed start date
(e.g. 2026-01-01), and calculate uptime only after that.
Question
Is there any CloudWatch-side way (Metric Math, SEARCH, Metrics Insights, etc.) to support Option 1?
Or is controlling the panel/dashboard time range effectively the only realistic approach, making Option 2 the correct solution in practice?
Thanks!
