CloudWatch + proxy problem
I am new to Grafana 5.1.3 and AWS. Does anyone have any experience with the following error? I get it when trying to Save & Test my CloudWatch data source. I am on GovCloud and behind a corporate proxy.
Thanks so much!
t=2018-06-14T18:58:31+0000 lvl=eror msg=“Metric request error” logger=context userId=1 orgId=1 uname=admin error=“Failed to call cloudwatch:ListMetrics, RequestError: send request failed\ncaused by: Post https://monitoring.us-gov-west-1.amazonaws.com/: dial tcp: lookup monitoring.us-gov-west-1.amazonaws.com on 10.250.0.10:53: no such host”
Running 5.2.0-beta1 manually works for me. Is it because of this 5.2.0 fix?
Login: Use proxy server from environment variable if available #9703, thx @iyeonok
It seems that it works if I just run from .tar.gz but does not work from yum install and service grafana-server start. Is there somewhere in a config that I need to put my proxy settings when the service runs???
Problem resolved for me now. I just had to add the following to my /etc/sysconfig/grafana-server
export http_proxy=http://myproxy:80
export https_proxy=http://myproxy:80
export no_proxy=‘host1, host2, host3, etc’
