Cloudwatch plugin - using wildcard with metric name does not work
Hi, I encountered the following case.
I have metrics in Cloudwatch for around 200 devices, that use the following pattern:
  • device.dev.cpu.827192
  • device.dev.cpu.742124
  • device.dev.cpu.494271
  • device.dev.cpu.321692
What I want to do in my dashboard is to have one query, that looks like this: “device.dev.cpu*”
that will retrieve all metrics which follow the specified pattern.
Sample screenshot:
Wildcards work perfectly fine in the AWS Cloudwatch console, but when I try to do the same in Grafana, I don’t receive any data. Also the query inspector does not display anything, so I cannot debug it or see if there is an error with the query itself.
If you guys have idea if this is even supported in the Cloudwatch plugin for Grafana, I would be happy to know.
Hi. I’m also need this feature. Maybe someone know a workaround?
I also need this feature. Any workaround known?
I’m also looking to solve this problem. I thought maybe it could be done by using variables but then when using variables you can not set up alerts. (https://github.com/grafana/grafana/issues/6557)
However, if you don’t need alerts, variables might be a good solution for you.
Hi jbulow,
Could you please provide a sample about how to use variables for this?
Not really but have a look at this and I think you shall manage: https://grafana.com/docs/reference/templating/#adding-a-variable
Hi @chh
Sample variable:
$redis = dimension_values(us-east-1,AWS/ElastiCache,CPUUtilization, CacheClusterId)
docs: https://grafana.com/docs/features/datasources/cloudwatch/
Please add this feature
