Cloudwatch Data Source - Legend as instance name instead of instance ID
I am using the Cloudwatch data source and from what I can see on the forums already it seems I can add:
{{InstanceId}}
In the alias box and it adds the instance ID there which is great. However, is there any way to get the instance name displayed there instead? I already get the instance name via the Name tag as a templating variable.
Thanks
Isn’t this answer your question Cloudwatch show servername instead of Instance ID - #2 by torkel ? :thinking:
