instide of claude ai , i want to use cloud grafana assistent.
i want to write promt here cloud grafana assistent and this will create the dashboard in my localhost like claude ai .
The two links you added are for grafana mcp server which is AFAIK a distinctly different product than assistant
If you want to create dashboards locally you can just use mcp server with Claude ai, cursor or visual studio code or n8n or other mcp clients against your local or cloud grafana instance
