Clickhouse Plugin : Support to show Loki logs corresponding to traces in clickhouse
Hey there,
I am using Grafana:10.4.0.
I send my application traces to clickhouse via the opentelemetry clickhouse exporter and use Loki with s3 as storage for Logs.
I have added both these datasources into Grafana.
Whenever I see a trace there is an option to show logs related to that particular trace this however redirects to the same clickhouse datasource saying To enable data linking, enter your default logs configuration in your ClickHouse Data Source settings
Is there a way to configure this logs configuration so that it will redirect to Loki the datasource instead?
