Clickhouse: Adding IF to $conditional_ALL Filter is not working
I’m Using Clickhouse Connector.
I’m putting this line in a Panel
AND $__conditionalAll( referer ${AND_referer} (${referer:sqlstring}), CASE WHEN ${referer} = ‘EMPTY’ THEN ‘’ ELSE ${referer:sqlstring} END)
But it’s seems like $__conditionalAll filter is not getting the value from the “CASE” sentence
I tried to change CASE to IF and I’m getting the same error.
Just doesn’t get the value from the “$referer” filter
It will be nice if you specify which datasource are you using, because each have own options. I guess it is Clickhouse.
Yes I’m using Clickhouse
