Check in Teardown
Can Check be invoked in teardown phase? I’ve tried it but it doesn’t seems to do anything. I would like to use Check in teardown to do final check of correctness after executing the load test. The final check consist of making a http request, so that using it inside load test will impa t the load test result.
Hi @rucciva,
This actually turned out to be really old bug that I have now made a fix for and is likely to get merged in v0.27.1, which is planned in the next 2 weeks.
