How to understand "check" metric
I have run the load test with single check for each request. after running whole test, I got result but I don’t know why the number of fails are not equals in the report. Please the image for detail.
Could anyone help me to clear this information?
Sincerely
HI @tandt, sorry for the late reply.
Could you give us a little bit more information? There shouldn’t be such a difference but maybe it is bug 949 which is due to the way we currently handle teardown and setup.
Where do you have your checks ? Are you using iterations, duration or stages to say how long your test should be?
Hi mstoykov,
My script does not contain setup and teardown. I just set duration for load test, and 1 check for each request.
@tandt, thanks for reporting this, unfortunately it is a bug in k6 and I created a new github issue to track it: Mismatch in check counts in the end-of-test summary · Issue #1033 · grafana/k6 · GitHub
The good news, as I’ve described in the issue, is that due to the current major refactoring of k6 internals in https://github.com/loadimpact/k6/pull/1007, we’re inadvertently in the process of fixing the bug.
