v8.5.0 (6134e3cf35) -
I wanted to create a pie chart from a table that show some calculation some rates. I want to categorize these values into some text. For example,
range: 1 - 0.5 → healthy
range: 0.5 - 0.3 → bitsick
range: 0.3 - 0 → sick
Then from this data I want to show the pie chart to count of every healthiness category, e.g healthy=3, bitsick=2, sick=1 -
These result is coming from 2 different data source, so I can only use transform to calculate or process between the 2 table. Once I got the value category, I want to use rows to field transform to calculate the count of each category. -
What happened?
There’s no transform feature that can map the value into some category, so I can’t show whether the value is on some category that I want to range. I try to use the rename by regex, but no clues.
