sometimes (e.g. if you use a beamer for presentation) the title text and legend text is too small for the audience.
Is there any way to change font size of graph title and/or legend text similar to gauge?
Thanks…
Thanks…
I was just wondering the same thing.
i have same issue for text files
Same problem here. Is there any solution?
I had the same problem and I also didn’t find a solution. One workaround that I did was to zoom my browser using CTRL++. It is not the best solution but I could take a screen shoot and everything was visible and proportional.
