Change datasource but keep panel settings
I have a panel with an sql datasource, lets say mssql, but want to change this to another sql datasource, lets say sqlite. When I edit the panel and select the other datasource, my settings are deleted, particularly the sql query.
Is there a way to keep all of the settings, besides manually copy-paste of everything?
welcome @marcus2945
instead of manually doing via the UI, try modifying it via the grafana api or manually edit the dashboard json
Thank you so much Josiah.
I was hoping for a way to use the Grafana UI, without erasing the sql query. If there is any.
