Hi teams,
I have this query to group and count the log_level
sum by(severity,level) (count_over_time({source="gitlab",zone="Staging", vm_name="lum1-cicd-1-a"}
| json
| logfmt
| drop __error__ , __error_details__ [$__range]
As you can see in the image, I have 2 fields of log level: severity and level. How can I change the field name from “severity” to “level”?
And some log levels have values in lowercase such as info, debug. Some log levels have value in uppercase such as INFO, DEBUG. How can I group log levels that have same value without lowercase or uppercase?
Thanks.
@tonyswumac, could you have a look at this?
I tried to use the relabel_configs, but it still does not work, here is my promtail config file:
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: https://loki.lumera-services.com/loki/api/v1/push
basic_auth:
username: lumsrv
password: configured
external_labels:
vm_name: ${HOSTNAME}
zone: Staging
export: loki
scrape_configs:
- job_name: system
static_configs:
- targets:
- localhost
labels:
source: sys-varlogs
__path__: /var/log/*log
- targets:
- localhost
labels:
source: sys-messages
__path__: /var/log/messages
- targets:
- localhost
labels:
source: sys-secure
__path__: /var/log/secure
- job_name: docker
docker_sd_configs:
- host: unix:///var/run/docker.sock
refresh_interval: 5s
relabel_configs:
- source_labels:
- __meta_docker_container_name
regex: /(.*)
target_label: source
- source_labels: [severity]
target_label: level
pipeline_stages:
- match:
selector: '{source="sys-varlogs"}'
stages:
- regex:
expression: '^(?P<time>\d{4}-\d{2}-\d{2}T\d{2}:\d{2}:\d{2}\+\d{4})\s+(?P<log_level>\S+)\s(?P<rest>.*)$'
- labels:
level: log_level
- match:
selector: '{source="nexus"}'
stages:
- regex:
expression: '^(?P<time>\d{4}-\d{2}-\d{2}\s\d{2}:\d{2}:\d{2},\d{3}\+\d{4})\s+(?P<log_level>\S+)\s+(?P<rest>.*)$'
- labels:
level: log_level
- match:
selector: '{source="jenkins"}'
stages:
- regex:
expression: '^(?P<time>\d{4}-\d{2}-\d{2}\s\d{2}:\d{2}:\d{2}\.\d+\+\d{4})\s*(?:\[(?:id=\d+)\])?\s*(?P<log_level>\S+)\s+(?P<rest>.*)$'
- labels:
level: log_level
- match:
selector: '{source="gitlab"}'
stages:
- json:
expressions:
timestamp: timestamp
message: message
level: level
- labels:
level:
1.) Use label_replace to rename label severity to level:
2.) Use lower to “normalize” value:
This is just advice, not a copy&paste solution. Make a few tries until you reach desired result on the LogQL level.
Many thanks @jangaraj ,
I tried to use label_replace but seem it not a good solution for me.
I used replace and it work for me.
For lower I tried to modify it from promtail before the logs will be sent to Loki. I used template, but it still not work. Here is my config:
- match:
stages:
- replace:
expression: "(severity)"
replace: "level"
- json:
expressions:
severity: severity
timestamp: time
message: message
level: level
- logfmt:
mapping:
timestamp: ts
caller: caller
level: level
unknown:
- labels:
severity:
message:
timestamp:
caller:
level:
- template:
source: level
template: '{{ ToLower .Value }}'
Could you have a look on my config?
Is there anything wrong?
Thanks
I gave you idea on LogQL level. Promtail is not my cup of tea.
