Can't switch smtp to MandatoryStartTLS on port 465
Hi All,
my Grafana 6.5.1 runs under windows. I’m not able to switch on TLS for encripted smtp communication.
My smtp connection over port 25 is working fine. Even a powershell script to test sending an email over 465 is working fine:
$userName = 'mydomain\my_smtpuser'
$secStringPassword = '**secret**' | ConvertTo-SecureString -Force -AsPlainText
$server = 'x.x.x.x'
$from = 'noreply@myadress.com'
$to = 'myname@myadress.com'
$subject = 'TLS mail test'
$body = ('TLS mail test using mail server!' -f $server)
[PSCredential] $credOject = New-Object PSCredential ($userName, $secStringPassword)
Send-MailMessage -SmtpServer $server `
 -To $to `
 -From $from `
 -Body $body `
 -Subject $subject `
 -Credential $credOject `
 -UseSsl `
 -Port 465
The smtp ip address is a windows mail proxy. My configuration is:
#################################### SMTP / Emailing #####################
[smtp]
enabled = true
# port 25 is working with the same config
#host = 1.2.3.4:25
host = 1.2.3.4:465
user = """xyz\abc"""
password = """xxxxxxx|"""
from_address = noreply@myadress.com
skip_verify = false
from_name = Grafana
ehlo_identity = grafana.app.mydomain.net
startTLS_policy = MandatoryStartTLS
The error message in grafana.log:
t=2020-11-05T11:25:36+0000 lvl=info msg="Sending alert notification to" logger=alerting.notifier.email addresses=[myname@myadress.com]
t=2020-11-05T11:25:36+0000 lvl=eror msg="Failed to send alert notification email" logger=alerting.notifier.email error="Failed to send notification to email address: myname@myadress.com: tls: first record does not look like a TLS handshake"
repeating last message two times.
That sounds like: Grafana didn’t switch on TLS for some reason.
Any suggestions?
Regards AAK
@aak did you find a solution? I have the same error.
