I can’t find the Mixed Datasource under Datasource. I am using Grafana v6.4.3, should be part of the native standard plugins as far as I see in Github: https://github.com/grafana/grafana/tree/9b7748ec133cb2ce4b092e523cb6d70a7b89de83/public/app/plugins/datasource/mixed
Any hints? Does it still exist?
Hi, @twei55!
Where are you looking for the mixed datasource? I think you look at Configuration -> Data Sources, but it’s not there. You can select it while setting up a new panel (or editing an existing one):
Best regards, Lukas
Thanks, Lukas. I was indeed looking at the wrong place
