Cant draw multiline graphs in Grafana new versions
Hi all,
I am using Grafana 10.1.1. I am trying to get a multiline chart like below.
Above chart is received from grafana 7.3
But In 10.11 its just received one line if I execute same query which I used in grafana 7.3.
Related Query.
SELECT
UNIX_TIMESTAMP(time) as time_sec,convert(action,CHAR(20)) as metric ,
SUM(hits_count) as “Action Count”
FROM scm_host_op_sp_service_action_channel_errorcode_wise_tps_hourly
WHERE
$__timeFilter(time)
Group by time,action
Thanks.
What is your datasource?Try the following
SELECT
UNIX_TIMESTAMP(time) as time,
WHERE
$__timeFilter(time)
Also make sure the fornat of the query is Time Series and not Table.
Also check that you do not have some Transformation that might having an effect on visualization
Hi, DataSource is MySQL. Finally got the solution. I transform it.
Then my yable in grafana change it as below.
Then I can draw multiline charts.
Thanks.
