Hi all,
I have installed the grafana-agent as instructed by the installer on Grafana Cloud, and I was trying to follow the installation guide for the Apache integration. Unfortunately it does not work.
The part that collects logs is OK. But the part where the integration is setup is not working properly.
Here is my config:
integrations:
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
regex: (prometheus_target_.*|prometheus_sd_discovered_targets|agent_build.*|agent_wal_samples_appended_total|process_start_time_seconds)
source_labels:
- __name__
apache_http:
enabled: true
instance: hostname
scrape_uri: 'http://localhost/server-status?auto'
agent:
enabled: true
# required for apache integration.
# scraping agent endpoint is required for apache histogram metric collection.
- source_labels: [exported_job]
target_label: job
- source_labels: [exported_instance]
- regex: (exported_instance|exported_job)
action: labeldrop
prometheus_remote_write:
- basic_auth:
password: XXXXX
username: XXXX
url: https://XXXXX/api/prom/push
logs:
I am getting this error:
Jun 5 12:33:59 grafana-agent[969634]: 2023/06/05 12:33:59 error loading config file /etc/grafana-agent.yaml: yaml: unmarshal errors:
Jun 5 12:33:59 grafana-agent[969634]: line 20: field agent already set in type integrations.ManagerConfig
Jun 5 12:33:59 systemd[1]: grafana-agent.service: Main process exited, code=exited, status=1/FAILURE
If I comment out the apache_http and the following agent sections, it works correctly.
Any idea?
