v12.0.1 and Linux
- What are you trying to achieve?
I am trying to edit datasources in the UI
- How are you trying to achieve it?
I am trying to navigate to where datasources are said to be in documentation, or where they were in v9, which was under Configuration > Data Sources.
- What happened?
Datasources are nowhere in the UI.
In v9, I can edit data sources as my logged in user, who has Admin permissions. In v12, I cannot even see the Connections tab, while I have Admin permissions to many other aspects, including user management. If I log on as the admin user (not ideal, or desired), I can see the Connections tab.
- Can you copy/paste the configuration(s) that you are having problems with?
I suppose this might be an auth issue, but our config is extremely limited
grafana.ini:
paths:
data: /var/lib/grafana/
logs: /var/log/grafana
plugins: /var/lib/grafana/plugins
provisioning: /etc/grafana/provisioning
analytics:
check_for_updates: true
log:
mode: console
grafana_net:
url: https://grafana.net
server:
root_url: https://grafana-dev.internal-domain.net
auth.generic_oauth:
client_id: $__file{/etc/secrets/grafana-jumpcloud-secrets/client_id}
client_secret: $__file{/etc/secrets/grafana-jumpcloud-secrets/client_secret}
auth_url: https://oauth.id.jumpcloud.com/oauth2/auth
token_url: https://oauth.id.jumpcloud.com/oauth2/token
api_url: https://oauth.id.jumpcloud.com/userinfo
enabled: true
allow_sign_up: true
scopes: email
users:
viewers_can_edit: true
auth:
sigv4_auth_enabled: true
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No, Connections is simply absent. Attached are images of my user logged in and of admin logged in.
