We are migrating from splunk to loki-grafana.
While migrating one of our dashboard we hit a road-block.
Problem statement:
Currently, we are generating logs in the following format:
2023-06-09 18:05:42.042 sampleJsonArray=[{“identifier”:“6c928ef1-8cac-4ed3-a855-232ceae17f7d”, “count”: 5}, {“identifier”:“bf9b11ec-721e-47a0-84a4-b3f192c9d6f4”, “count”: 7}, {“identifier”:“c07d9a2e-1219-446e-885f-2b3a302c486c”, “count”: 5}]
2023-06-09 18:05:43.042 sampleJsonArray=[{“identifier”:“6c928ef1-8cac-4ed3-a855-232ceae17f7d”, “count”: 3}]
2023-06-09 18:05:44.042 sampleJsonArray=[{“identifier”:“bf9b11ec-721e-47a0-84a4-b3f192c9d6f4”, “count”: 2}, {“identifier”:“c07d9a2e-1219-446e-885f-2b3a302c486c”, “count”: 8}]
We need to figure out the sum of all the count value per identifier
Identifier | Count
6c928ef1-8cac-4ed3-a855-232ceae17f7d | 8
bf9b11ec-721e-47a0-84a4-b3f192c9d6f4 | 9
c07d9a2e-1219-446e-885f-2b3a302c486c | 13
We did try out some transformation e.g.: ‘Extract Fields’ → JSON
And using table to visualise the result. But this doesn’t work.
I am trying to compute such logs is by expanding each line of sampleJsonArray into multiple lines (each line with same timestamp possibly) with one json object per line (and then use some kind of reduce/group by transform). in splunk we used mvexpand.
I am not able to find any way to expand a row into such multiple rows.
Not sure, if this is even possible with Loki-grafana.
