I have setup Grafana 9.4.7 with Docker and behind an reverse proxy.
My docker environment also contains a InfluxDB server and telegraf. If I go to the data source management page in Grafana and select “InfluxDB” I get the message:
Unknown Plugin
Data Source Error
Error 404.
Do you have any suggestions?
I don’t know if it’s Docker related but here is the Dockerfile:
version: '3.1'
services:
influxdb:
image: influxdb:1.8.10-alpine
container_name: influxdb
restart: always
environment:
- INFLUXDB_DB=influx
- INFLUXDB_ADMIN_USER=xxx
- INFLUXDB_ADMIN_PASSWORD=xxx
ports:
- '8086:8086'
volumes:
- influxdb_data:/var/lib/influxdb
telegraf_dev:
image: telegraf:1.24
container_name: telegraf_dev
volumes:
- /d/Docker/monitor/telegraf.conf:/etc/telegraf/telegraf.conf
ports:
- 9100:9100
depends_on:
- influxdb
grafana_dev:
image: grafana/grafana:9.4.7
container_name: grafana_adam_dev
ports:
- 3001:3000
links:
- postgres_dev
- influxdb
volumes:
- /d/Grafana/development/storage:/var/lib/grafana
- /d/Grafana/development/custom.ini:/etc/grafana/grafana.ini
depends_on:
- postgres_dev
- influxdb
postgres_dev:
image: postgres:15.2
container_name: postgres_dev
environment:
POSTGRES_USER: postgres
POSTGRES_PASSWORD: xxx
POSTGRES_DB: postgres
PGDATA: /var/lib/postgresql/data/pgdata
ports:
- 5433:5432
volumes:
- /d/postgres/development/data:/var/lib/postgresql/data
volumes:
influxdb_data: {}
