I need to create a selection window in a Grafana dashboard that only shows 3 characters that’s been parsed from a hostname queried from InfluxDB. I’m able to query the hostname as a variable; can REGEX be used to parse out the 3 unknown characters starting at a fix position? The hostname length will always be 8 characters and I need to parse out characters 4,5 and 6 from the string. The 3 characters represents airport codes. If possible, please provide a REGEX example.
— examples—
Hostname:
ABCSEA31
ROUORD45
ZXCSMF23
Desired REGEX output to be used as variables in dashboard selection window.
SEA
ORD
SMF
v6.3.7 -
Uses REGEX as a Query Options under Settings->Variable. -
What happened?
