Can I use multiple SQL statements in a single MySQL query?
    Grafana v11.4.0 (b58701869e)
    Before using AES_DECRYPT() , set SET SESSION block_encryption_mode = 'aes-256-ecb';
    I wrote two lines of SQL in one query, and it resulted in an error.
    I split them into two queries, but the query order is sometimes reversed, which prevents the AES decryption parameters from being set.
  • What happened?
    Saving error or decryption failure.
    I can directly modify parameters in an SQL query, or use SET and SELECT statements simultaneously in a single query, or set dependencies between multiple queries to affect the query order.
    The SQL statement has been de-identified.
    SELECT
      col_a,
      AES_DECRYPT(
        FROM_BASE64(col_b),
        col_c
      ) AS col_x,
      col_d
    FROM
      schema_x.table_y
    WHERE
      col_a IN (<LIST_1>)
      OR
      col_a IN (<LIST_2>);
    db query error: Error 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'SELECT col_a, AES_DECRYPT( FROM_BASE64(col_b), col_c ' at line 2
    • no
Copy that query out of grafana and run in a mysql query tool
What do you see
  1. It works correctly in MySQL client tools.
  2. Executing the SQL statements as two separate queries has a chance of successful decryption and a chance of failure. Sometimes refreshing the page can restore functionality.
Hi @huangsijun17 ,
You can’t use two SQL lines in one query it will through the error, so the solution is creating a MySQL stored procedure.
Inside the procedure, we run both the session setting and the query together:
For example :-
CREATE PROCEDURE get_users_decrypted()
BEGIN
SET SESSION block_encryption_mode = ‘aes-256-ecb’;
      SELECT
                 id,
                 username,
                 CAST(AES_DECRYPT(email_enc, 'key') AS CHAR) AS email,
                 dept
       FROM users
       ORDER BY id;
END;
Then in Grafana, the query becomes:
CALL grafana_demo.get_users_decrypted();
Here is the result -
If you need anything else, please let me know.
