Hello, I want to set the language ‘Administration.General.Default preferences.Language’ to 中文
Can I done this by grafana.ini? (or by api without manual operation)
default_language
This option will set the default UI language if a supported IETF language tag likeen-USis available. If set todetect, the default UI language will be determined by browser preference. The default isen-US.
I have been set the language to
# Default UI language (supported IETF language tag, such as en-US)
default_language = zh-CN
but it didnt work.
Set it in UI manually is work. ![]()
Try:
default_language = zh-Hans
