Can I execute an SQL query from the panel using JavaScript?
    grafana v10.2.3, windows 10
    I’m using js fetch() inside Html Graphics plugin like this:
const query = `SELECT * FROM test;`
  const refId = "A";
  const datasource = {
    "type": "mssql",
    "uid": "uid" // I'm using correct uid
  const { from, to } = data.timeRange;
  const body = {
    queries: [
        datasource,
        query,
        refId,
        intervalMs: 0,
        maxDataPoints: 1e9,
    to: String(to.valueOf()),
  fetch("/api/ds/query", {
    headers: {
      "connection": "keep-alive",
      "content-type": "application/json",
    body: JSON.stringify(body),
    method: "POST",
    .then((res) => {
      console.log(res);
    .catch(console.error);
  • What happened?
    the response is empty but status says OK, 200
    I expect to receive data from the server; the query is okay and returns data in SQL Server Management Studio
    Nope
    Export to CSV (influx2) | HTMLGraphics
