I am trying to calculate the elapsed time between the most recent time stamp and the second most recent time stamp to find the time it took between two events.
- How are you trying to achieve it?
Currently, I am only able to see a log several most recent time stamps and don’t see a clear way to create the calculation desired. I am pulling in the data, running a “filter by name” transform to pull only the @timestamp, the inputting it as a custom “time: hh:mm:ss” unit to show this panel.
- Can you copy/paste the configuration(s) that you are having problems with?
The data is all based off of the timestamps of events as shown below
