Surely possible, but depends on what data source you decide to use in Grafana, i.e. the data source where you’ll store the monitored power consumption. If you use graphite or prometheus as data source to name a few it’s easy to divide one measurement with another since that supported in the query language of the time series databases. With other time series databases it can be tricky. to do query wise and you may need to do these kind of calculations before writing them to the database.
I’m using datasource Elasticsearch, and I need to calculate KPIs also (for example dividing one measurement with another). I can’t do this calculation before writing to the database. So, is it any solution to do this for Elasticsearch datasource and Graph panel?
