So, I have a dataset which has time stamp column and the cumulative value column, what I want to do is calculate the difference of the current cumulative value from the previous one so I can get the actual value and the difference of all those values need to be summed up and get a single value, example C2=B3-B2, C3=B4-B3 and so on and at last C2+C3+C4 and so on. I have attached my dataset sample below.
My query is as follows:
from(bucket: "Bacnet_Network")
|> range(start: 2022-01-01T00:00:00Z, stop: 2022-12-31T23:59:59Z)
|> filter(fn: (r) => r["_measurement"] == "048_STEM")
|> filter(fn: (r) => r["sensor"] == "472200_AV_210_STEM_HRC2_GJ_EXPORT_AV")
|> difference(nonNegative: false, columns: ["_value"])
|> aggregateWindow(every: 1mo, fn: sum, createEmpty: false)
|> group(columns: ["sensor"])
|> sum(column: "_value")
|> drop(columns: ["host", "system", "unit", "topic", "objects_type", "name", "_measurement"])
The answer that I am getting is not correct and does not match with the raw data. Any suggestions?
THANK YOU!!
