I’ve just discovered go language and it seems we can build packages from every architecture from the same sources right ?
So I did a fork of grafana and I did some changes in front end (tsx files) and some on back end (go files). Now I can build easily for my environment with the command: go run build.go build package
1/ where I can find the files to deploy.
- %GOPATH%\src\github.com\grafana\grafana\bin\windows-amd64\grafana-server.exe ? (the backend right ?)
- the front end from %GOPATH%\src\github.com\grafana\grafana\public ?
2/ what is the file grafana-cli.exe ?
3/ Can I make a build for a debian distrib from my windows source code ?
Thanks and happy to be on board
