I am trying to create scene app in grafana 10 , can anyone help me with this?
I have grafana 10 running on Linux host? Do i need to run create new plug on Linux host (where grafana is running or I can do it locally) ,
I find grafana documents not easy to follow or they assume lot of things which I am not aware
What happened?
