9.0.7
- What are you trying to achieve?
I’m trying to get prometheus to alert if an interface with a particular description is operationally up but administratively down.
- How are you trying to achieve it?
I’m trying to achieve it using a custom alert expression, which isn’t working
- What happened?
The expression doesn’t return any values and therefore doesn’t trigger an alert.
I’d expect an alert to be triggered for an interface operationally down but administratively up if it’s description contailed the letters ‘OSN’.
- Can you copy/paste the configuration(s) that you are having problems with?
ifOperStatus != 1 and ifAdminStatus == 1 and ifDescr{ifDescr=".*OSN.*"}
In the above, the value is the exact output but is realistically 70 degrees celsius, in the same way that an output of 316 would be 31.6 degrees celsius.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No alerts to speak of
- Did you follow any online instructions? If so, what is the URL?
n/a
