Hi, I am currently running into an issue.
I would like to setup the 24 hours retention for loki.
Here is my current configuration:
auth_enabled: false
server:
http_listen_port: 3100
common:
path_prefix: /loki
replication_factor: 1
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
final_sleep: 0s
chunk_idle_period: 1h
max_chunk_age: 1h
chunk_target_size: 1048576
chunk_retain_period: 30
max_transfer_retries: 0
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v13
index:
prefix: index_
period: 24h
storage_config:
filesystem:
directory: /loki/chunks
compactor:
working_directory: /loki/compactor
retention_enabled: true
compaction_interval: 10m
delete_request_store: filesystem
shared_store: filesystem
retention_delete_delay: 30m
retention_delete_worker_count: 150
limits_config:
retention_period: 24h
allow_structured_metadata: false
reject_old_samples: false
chunk_store_config:
max_look_back_period: 24h
ruler:
storage:
type: local
local:
directory: /loki/rules
rule_path: /loki/rules-temp
alertmanager_url: http://localhost:9093
ring:
kvstore:
store: inmemory
enable_api: true
When I setup it into my grafana, I can still see the logs past 24 hours, seems like the retention does not work.
Do you have any idea how I can patch it ?
Is it possible to setup it through tsdb ?
Thanks in advanced
