i’m a french developper, that I’m trying to use the open-source stack of grafana. I have grafana, mimir, tempo and loki.
Grafana and Tempo are deployed on one server. Mimir on a other server. Loki on a third server.
Each stack had their own configuration, and all run almost perfectly.
But with Loki, I had issues. I have 20Go on the server to store logs, and I tried to configure to have 1h of retention logs.
But in 8 days, it’s runing out stockage.
I have an idea of the process. If I have 1h of logs retention, and I get the logs of all my backends in 1h, either I have enough storage during this hour to collect and delete logs (and that’s good).
Either, I do not have enough storage to collect and delete the logs, and in one hour, my 20 Go are full ?
Tell me if I’m wrong ?
But in my case, i have the figure : (in x-axis this days of the month)
I start my loki with docker compose :
services:
loki:
image: grafana/loki:latest #3.1.2 # grafana/loki - Docker Image and Releases · grafana/loki · GitHub
network_mode: bridge
command: [‘-config.file=/etc/loki/local-config.yaml’]
volumes:
- ./loki.yml:/etc/loki.yml:ro
ports:
- “3100:3100”
This is my configuration :
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 1h
storage_config:
boltdb_shipper:
active_index_directory: /loki/index
cache_location: /loki/index_cache
shared_store: filesystem
filesystem:
directory: /loki/chunks
Configuration cruciale pour la rétention avec boltdb-shipper et filesystem
table_manager:
retention_deletes_enabled: true
retention_period: 1h # Exemple pour 7 jours
# working_directory: /loki/table-manager # Chemin pour les opérations du table_manager
#limits_config:
#retention_periods:
#chunk: 1h
#index: 1h
max_outstanding_per_tenant: 4096
compactor:
retention_enabled: true
working_directory: /loki/compactor # Ou un autre chemin pour les opérations du compacteur
compaction_interval: 10m # Exemple
retention_delete_delay: 1h # Délai avant la suppression effective
retention_delete_worker_count: 150 # Nombre de workers
apply_retention_period: 1h # Ex: 7d, 168h
Tell me if my configuration is wrong and how to improve it ?
Thank you for your help,
David Lhullier
