The reason your previous attempts failed is that you were only updating datasource.name → you also need to update datasource.type and datasource.uid. Additionally, datasource references exist in 4 places inside a dashboard JSON → panels, query targets, template variables, and annotations all of which need to be updated.
One more important thing → the DoiT plugin is Angular-based and Grafana 13 has completely removed Angular support. If you are upgrading to Grafana 13+, the DoiT plugin will stop working entirely.
You can use this Python script
python
import requests
import copy
import logging
from datetime import datetime
GRAFANA_URL = "http://your-grafana-host:3000"
API_KEY = "your-grafana-admin-api-key"
OLD_DATASOURCE_TYPE = "doitintl-bigquery-datasource"
OLD_DATASOURCE_UID = "your-old-uid"
NEW_DATASOURCE_NAME = "BigQuery"
NEW_DATASOURCE_TYPE = "grafana-bigquery-datasource"
NEW_DATASOURCE_UID = "your-new-uid"
DRY_RUN = True
logging.basicConfig(
level=logging.INFO,
format="%(asctime)s [%(levelname)s] %(message)s",
handlers=[
logging.FileHandler(f"migration_{datetime.now().strftime('%Y%m%d_%H%M%S')}.log"),
logging.StreamHandler()
log = logging.getLogger(__name__)
HEADERS = {"Authorization": f"Bearer {API_KEY}", "Content-Type": "application/json"}
def get_all_datasources():
resp = requests.get(f"{GRAFANA_URL}/api/datasources", headers=HEADERS)
resp.raise_for_status()
return resp.json()
def get_all_dashboards():
resp = requests.get(f"{GRAFANA_URL}/api/search", headers=HEADERS, params={"type": "dash-db", "limit": 5000})
return resp.json()
def get_dashboard(uid):
resp = requests.get(f"{GRAFANA_URL}/api/dashboards/uid/{uid}", headers=HEADERS)
return resp.json()
def save_dashboard(dashboard_json, folder_uid):
payload = {"dashboard": dashboard_json, "folderUid": folder_uid, "overwrite": True, "message": "Migrated from DoiT to native Grafana BigQuery"}
resp = requests.post(f"{GRAFANA_URL}/api/dashboards/db", headers=HEADERS, json=payload)
return resp.json()
def is_doit(ds):
if not isinstance(ds, dict):
return False
return ds.get("type") == OLD_DATASOURCE_TYPE or ds.get("uid") == OLD_DATASOURCE_UID
def replace_ds(ds):
updated = copy.deepcopy(ds)
updated["type"] = NEW_DATASOURCE_TYPE
updated["uid"] = NEW_DATASOURCE_UID
if "name" in updated:
updated["name"] = NEW_DATASOURCE_NAME
return updated
def migrate_panel(panel):
panel = copy.deepcopy(panel)
changed = False
if is_doit(panel.get("datasource")):
panel["datasource"] = replace_ds(panel["datasource"])
changed = True
for target in panel.get("targets", []):
if is_doit(target.get("datasource")):
target["datasource"] = replace_ds(target["datasource"])
changed = True
if "panels" in panel:
new_panels = []
for sub in panel["panels"]:
updated_sub, sub_changed = migrate_panel(sub)
new_panels.append(updated_sub)
changed = changed or sub_changed
panel["panels"] = new_panels
return panel, changed
def migrate_dashboard(full_response):
dashboard = copy.deepcopy(full_response["dashboard"])
total_changed = 0
new_panels = []
for panel in dashboard.get("panels", []):
updated, changed = migrate_panel(panel)
new_panels.append(updated)
if changed:
total_changed += 1
dashboard["panels"] = new_panels
for var in dashboard.get("templating", {}).get("list", []):
if is_doit(var.get("datasource")):
var["datasource"] = replace_ds(var["datasource"])
total_changed += 1
for ann in dashboard.get("annotations", {}).get("list", []):
if is_doit(ann.get("datasource")):
ann["datasource"] = replace_ds(ann["datasource"])
total_changed += 1
return dashboard, total_changed
def run_migration():
log.info(f"Migration started | DRY_RUN={DRY_RUN}")
log.info("Available datasources:")
for ds in get_all_datasources():
log.info(f" {ds['name']} | {ds['type']} | uid={ds['uid']}")
dashboards = get_all_dashboards()
log.info(f"Total dashboards: {len(dashboards)}")
summary = {"migrated": 0, "skipped": 0, "errors": 0}
for dash in dashboards:
uid, title = dash["uid"], dash["title"]
try:
full_response = get_dashboard(uid)
folder_uid = full_response.get("meta", {}).get("folderUid", "")
updated, total_changed = migrate_dashboard(full_response)
if total_changed == 0:
log.info(f" SKIP | {title}")
summary["skipped"] += 1
continue
log.info(f" MATCH | {title} — {total_changed} reference(s) to update")
if not DRY_RUN:
updated.pop("id", None)
save_dashboard(updated, folder_uid)
log.info(f" SAVED | {title}")
else:
log.info(f" DRY | {title} (no changes applied)")
summary["migrated"] += 1
except Exception as e:
log.error(f" ERROR | {title} (uid={uid}): {e}")
summary["errors"] += 1
log.info(f"Done | Migrated={summary['migrated']} Skipped={summary['skipped']} Errors={summary['errors']}")
if DRY_RUN:
log.info("DRY_RUN=True — set to False to apply changes")
if __name__ == "__main__":
run_migration()
Before running:
Take a Grafana DB backup first
Run GET /api/datasources to confirm your exact DoiT type and uid and fill them in the config
Run with DRY_RUN = True first to verify output before applying changes
Test on QA before production
