Bar Chart Not Displaying If MySQL Query Has Single Row Returned
I am using Grafana 8.3.4. I have a mysql datasource. When the query returns a single row, the Bar Chart does not show any bars. It shows bars only when more than one row is returned by the query.
Below is the bar chart graph view
Below is the bar chart table view
hi @rinkusingh111
can you please report this as a bug in the grafana repo? I couldn’t get this working with dummy data either
Try putting this as your Display Name: ${__field.labels.X} as suggested on this thread: Grafana Legend showing label filters name - #3 by rayhernandez
You can try this solution to solve your problem. i hope it will be helpfull for you I have tested it with both single and multiple rows.
For single row, I did it like this…
For multiple, I did it like this…
Hello @rinkusingh111
Just checking in—did this solution resolve your issue, or are you still experiencing the same problem?
