Hi there,
we are experiencing a weird bug on our project where after every iteration is finished, one request drops with an error > response 0.
This is causing a lot of bad requests with bigger runs.
K6 v0.52.0
Here is an example with 5 VU run
Also, here is an example where I interrupted the run before any iteration was finished, and different error is shown
Here is example with 46 interrupted iterations and 46 bad requests
Hey @mlovric !
It’s hard to tell just by looking at the logs
. One thing that I could guess is that response 0 (and EOF) means that the server did not respond but probably closed the connection.
Could you please provide a minimal example of the script you’re trying to run (without any business details)? Has it started recently? Also, what are K6’s flags/options? For instance, what if you run k6 with the no connection reuse setting?
Cheers!
The first line of this picture says that response code is 404. This means that the resource/url you try to access is not exists on the server.
