Greetings all. We have an existing Grafana 6.6.2 install on CentOS 7.8 using nginx for the user-facing SSL proxy. It’s configured with AzureAD authentication which was (up until last week)_working properly. There doesn’t appear to be anything that’s changed and static logins are still fine. Behaviorally, new logins will correctly forward to the company’s microsoftonline login dialog, send two-factor confirmations via SMS, etc. The redirect query following auth back to grafana is hanging. Here’s the relevant setup (anonymized a bit).
From grafana.ini
##################################### Azure Oauth ####################
[auth.generic_oauth]
name = AzureAD SSO
enabled = true
allow_sign_up = true
client_id = c5a49c03-a339-46d0-af6f-*************
client_secret = 6zQ?h8FQiv@1vI7Il?a***************
scopes = openid email profile
auth_url = h44ps://login.microsoftonline.com/9feebc97-ff04-42c9-a152-76********/oauth2/v2.0/authorize
token_url = h44ps://login.microsoftonline.com/9feebc97-ff04-42c9-a152-76********/oauth2/v2.0/token
allowed_domains = company.com
;allowed_domains =
;allowed_groups =
Nginx error message:
2021/02/17 17:47:54 [error] 99280#0: *3185 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 10.63.144.220, server: inet-dashboard.services.company.net, request: “GET /login/generic_oauth?code=0.AAAAl7zunwT_yUKhUnZwc4chGAOcpMU5o9BGr28S4NX1e2MOAKs.AQABAAIAAAD–DLA3VO7QrddgJg7Wevr1wwm2sea6b8Y4VgQlCRiwGKMcmRGH6oKDitxnCFVexv5nnhSF3p64GW3l9S8qrb2Xa7rgDsBXTjzLuYViP0xp20QyG4lonfj6ZOv4eIVqt_IiSVBJP8IeRGOyXf5_nEBk_qcwuRMjGVhE-uugI2mjj3fl8T-EUpQuyHMk04wBUe-IHcTT_stupyag3Y43WUQdLz28NcvKTFjbvhdxiwz4nvZdV7DrtYuvTMBxWeMUEZu6JVRIbXppNYp8v3iM-0P8dCW63-WHqe7X9sckLn_Q7CQYzuciiv4Csj4NGnnE_kxX1kAMfmZxA0UfTH06jZziDOQBRuThEvc6bPNd1rIKhuhknsJ-l2ZFmn_zbTBem9VnjwFFEz4IslyLfiINhbtnPtFqFje_At0cGPx8vaXijY8zJNLeNKM97ly0S1hxrBpe3HszsD5-yF0dtPcPrXjnk2V9JSW_dduSLewZ2u79jHL6y-uCg2jkWKKIOM7cDqBsbNCINeF4Tk8grBigalmJ0kvnoQYxSfxNOz_3pRwzQxkMsQe-5WXAxpp9mB8CfiZPX-rkhieDC9f64SeXmkV9q5cd2-GVhptaHMS1SgtyDRh9KiH5lamgGE3qSqfmFVXGbsKw9OQQpMg5zFV3shvG6zXpqJNQWEO4UdjSpdj3cCFicitbaxyOiAjx_jh-dTSFAJ49td-S7hkNnX0N3rA1ujxQZmgXTDeoh5u1_hSokEFa4JWF1AhdWIw077z-D1CVh7j9E6QocTC3Szk0_AmFCUvN5E14YZiXE6D5GlN-t98EDykRVct2_43qTp8uasHMPLB1I-L7efuQ2dCSir2WLytbtH7dsr1rM147jOdxi-KL5RZa9SQoG1ZpfmQEFUgAA&state=bEwGbZOA-luf2g8NM-mMCRztKurDpdcP8tIHQ6MdNXo%3d&session_state=9527d858-bb4a-4cae-a4f7-89b53c5eaae7 HTTP/2.0”, upstream: "h44p://127.0.0.1:3000/login/generic_oauth?code=0.AAAAl7zunwT_yUKhUnZwc4chGAOcpMU5o9BGr28S4NX1e2MOAKs.AQABAAIAAAD–DLA3VO7QrddgJg7Wevr1wwm2sea6b8Y4VgQlCRiwGKMcmRGH6oKDitxnCFVexv5nnhSF3p64GW3l9S8qrb2Xa7rgDsBXTjzLuYViP0xp20QyG4lonfj6ZOv4eIVqt_IiSVBJP8IeRGOyXf5_nEBk_qcwuRMjGVhE-uugI2mjj3fl8T-EUpQuyHMk04wBUe-IHcTT_stupyag3Y43WUQdLz28NcvKTFjbvhdxiwz4nvZdV7DrtYuvTMBxWeMUEZu6JVRIbXppNYp8v3iM-0P8dCW63-WHqe7X9sckLn_Q7CQYzuciiv4Csj4NGnnE_kxX1kAMfmZxA0UfTH06jZziDOQBRuThEvc6bPNd1rIKhuhknsJ-l2ZFmn_zbTBem9VnjwFFEz4IslyLfiINhbtnPtFqFje_At0cGPx8vaXijY8zJNLeNKM97ly0S1hxrBpe3HszsD5-yF0dtPcPrXjnk2V9JSW_dduSLewZ2u79jHL6y-uCg2jkWKKIOM7cDqBsbNCINeF4Tk8grBigalmJ0kvnoQYxSfxNOz_3pRwzQxkMsQe-5WXAxpp9mB8CfiZPX-rkhieDC9f64SeXmkV9q5cd2-G
and the nginx snippet:
location / {
rewrite /(.*) /$1 break;
proxy_pass h44p://inet-dashboard.services.company.net:3000;
proxy_redirect off;
proxy_set_header Host $http_host;
Any thoughts on what might have broken here? (note: web URLs replaced with “h44p” to allow me to post the contents without hitting the noob filter).
Thanks.
Dan
