Azure AD: "user not a member of one of the required groups"
Hi folks, I am new to Grafana and I just followed the wiki to set up Azure AD auth for our Grafana portal, But i always get the error like that:
t=2021-02-20T07:57:36+0000 lvl=eror msg=“login.OAuthLogin(get info from azuread)” logger=context userId=0 orgId=0 uname= error=“user not a member of one of the required groups”
t=2021-02-20T07:57:36+0000 lvl=eror msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/login/azuread status=500 remote_addr=**** time_ms=1225 size=1745
That is wired, i tried the method from 23358, but failed.
I both set :
“groupMembershipClaims”: “ApplicationGroup, SecurityGroup”,
and
_“appRoles”
But the error remains.
Anything else missed?
Thank you guys in advance.
BTW, my Grafana config is like:
#################################### Azure AD OAuth #######################
[auth.azuread]
name = Azure AD
enabled = true
allow_sign_up = true
client_id = <>
client_secret = <>
scopes = openid email profile
auth_url = <Cannot past here as atmost 2 links i can past>
token_url = <Cannot past here as atmost 2 links i can past>
allowed_domains = mycompany.com
allowed_groups = 17d51234-06f4-1234-1234-9ff123411234
Did we get the solution for the above issue. getting the same error.
Did we get the solution to the above problem? We are also getting the same error
By any chance, did we get the solution to the above problem?
