AWS Grafana GameLift Hard Coded Metrics
  • What are you trying to achieve? Ingesting GameLift Metrics From CloudWatch found that not all GameLift metrics are provided from drop down as they are hard-coded
Have to manually enter metrics such as
AvailableGameServers
DrainingUtilizedGameServers
DrainingAvailableGameServers
UtilizedGameServers
These are standard GameLift Fleet IQ metrics as per AWS documentation [1]. Attaching screen-shots for reference.
Can you please add these metrics to Grafana
[1] https://docs.aws.amazon.com/gamelift/latest/developerguide/monitoring-cloudwatch.html
That drop down is there only for your convienence. But you can write any metric (the same apply for dimension, namespace, statistic, …) name - just follow UI instructions:
And of course the best way is to create PR, where you will add those missing metrics, so they will be available in the drop down in the future.
Thanks I have created Pull Request to add the missing metrics added GameLift metrics to /pkg/tsdb/cloudwatch/constants/metrics.go by doitwithciara · Pull Request #72805 · grafana/grafana · GitHub
