Grafana v10.4.8 on Ubuntu 20.04.6 -
Use a provisioned OpenSearch data source. Opensearch is running on the same machine as Grafana. -
If I use the datasource API to access the data source without a proxy, it works, or at least returns the datasource information:
curl --insecure -GET http://localhost:3000/api/datasources/uid/f990c0c6-a920-41c2-8b3e-a43e6ff9234a/
{"id":36,"uid":"f990c0c6-a920-41c2-8b3e-a43e6ff9234a","orgId":1,"name":"perfSONAR Local","type":"grafana-opensearch-datasource","typeLogoUrl":"public/plugins/grafana-opensearch-datasource/img/logo.svg","access":"proxy","url":"https://localhost/opensearch","user":"","database":"","basicAuth":false,"basicAuthUser":"","withCredentials":false,"isDefault":true,"jsonData":{"database":"pscheduler*","flavor":"opensearch","maxConcurrentShardRequests":5,"pplEnabled":true,"timeField":"pscheduler.start_time","tlsAuth":false,"tlsSkipVerify":true,"version":"2.6.0"},"secureJsonFields":{},"version":1,"readOnly":true}
- What happened?
If I use the proxy, however, which should mimic the behavior of the dashboards using this datasource, I get an error:
curl --insecure -GET http://localhost:3000/api/datasources/proxy/uid/f990c0c6-a920-41c2-8b3e-a43e6ff9234a/
Authentication to data source failed
I expected to get the data that the datasource is supposed to supply. The “Authentication to data source failed” error is also visible on the web interface. When I load it, I get the following error:
Templating [node_name]
Error updating options: OpenSearch error: Authentication to data source failed -
The provisioned datasource configuration can be seen above, in the API response. -
The above error is observed in the UI. The “Authentication to data source failed” error is the only one I observe in the log file, even with logging set to debug. Immediately before this error, I do see several messages saying
logger=folder.permissions t=2024-12-18T00:40:20.597400744Z level=debug msg="Access denied to folder" namespaceID=anonymous userId= orgID=1 uid=e65dd0fc-fd6d-45c2-a8bb-f6df1186cf66 permissions="all(action:folders.permissions:read scopes:folders:uid:e65dd0fc-fd6d-45c2-a8bb-f6df1186cf66 action:folders.permissions:write scopes:folders:uid:e65dd0fc-fd6d-45c2-a8bb-f6df1186cf66)"
However, I’m not sure if this is relevant. If I explicitly perform the curl command using the admin user, the same authentication error is observed.
- Did you follow any online instructions? If so, what is the URL?
No, but I didn’t come up with this myself, the setup is part of the Perfsonar traffic monitoring package
