I’m trying to work on a custom HTML panel for a scripted dashboard, but having some issues with .ready() binding.
I’ve added the following panel to the scripted_async.js script:
"content": "<!DOCTYPE html>\n<html lang=\"en\">\n <head>\n <link rel=\"stylesheet\" href=\"https://cdnjs.cloudflare.com/ajax/libs/materialize/0.100.2/css/materialize.min.css\">\n <style>\n .input-field.col .dropdown-content [type=\"checkbox\"]+label {\n top: -10px;\n }\n </style>\n </head>\n <body>\n <div class=\"container\">\n <div class='input-field col s3'>\n <select class='multiselect' multiple>\n <option value=\\\"\\\" disabled selected>Datacenter</option>\n <option value=\\\"dub\\\">dub</option>\n <option value=\\\"ams\\\">ams</option>\n <option value=\\\"iad\\\">iad</option>\n <option value=\\\"rs-iad\\\">rs-iad</option>\n <option value=\\\"rs-lhr\\\">rs-lhr</option>\n <option value=\\\"rs-ord\\\">rs-ord</option>\n <option value=\\\"unknown\\\">unknown</option>\n </select>\n </div>\n </div>\n <!-- Latest compiled JavaScript -->\n <script src=\"https://cdnjs.cloudflare.com/ajax/libs/materialize/0.100.2/js/materialize.min.js\"></script>\n <script type=\"text/javascript\">\n $(document).ready(function() {\n $('.multiselect').material_select();\n });\n </script>\n </body>\n</html>",
"id": 1,
"mode": "html",
"span": 12,
"title": "Panel Title",
"type": "text",
"links": []
An expanded version of the html bit is here:
<html lang="en">
<head>
<link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/materialize/0.100.2/css/materialize.min.css">
<style>
.input-field.col .dropdown-content [type="checkbox"]+label {
top: -10px;
</style>
</head>
<body>
<div class="container">
<option value=\"\" disabled selected>Datacenter</option>
<option value=\"dub\">dub</option>
<option value=\"ams\">ams</option>
<option value=\"iad\">iad</option>
<option value=\"rs-iad\">rs-iad</option>
<option value=\"rs-lhr\">rs-lhr</option>
<option value=\"rs-ord\">rs-ord</option>
<option value=\"unknown\">unknown</option>
</select>
</div>
</div>
<script src="https://cdnjs.cloudflare.com/ajax/libs/materialize/0.100.2/js/materialize.min.js"></script>
<script type="text/javascript">
</script>
</body>
</html>
When I navigate to the dashboard, my dropdown doesn’t show up until I make some sort of action on the dashboard (manually edit the html through the edit menu or something other that I assume triggers the $(document).ready() again) – is there a better way to do this so that my panels fully generate when the page loads?
It seems similar issues happen without using $(document).ready() – if I try something like just $('.multiselect').material_select(); I get console errors about material_select() not being a recognized function; I don’t however get any errors about the jQuery selector $('.multiselect') so I assume this has something to do with my external styles / js not getting loaded when the page loads? I’m not really sure - I’ll keep playing around.
