Would it be possible to perform some simple arithmetic operations (addition, multiplication) on variables with a numerical value and use the result as a new variable?
do you developing you custom plugin?
for example if we have some sql plugin in use, we can write query like:
select hostname, max(network.send* $multiplier)
from
hardware
after that query variables replaced with variable value, for example
select hostname, max(network.send* 1024)
from
hardware
I was hoping I would be able to do something like:
$NewVar = $MyVar1 * $MyVar2
@kempeng I have the exact use case. At the moment I manually calculate and then use the result as constant variable. Were you able to find any solution for this?
