App based on Grafana available from an URL
Hi all,
I am trying to build a dashboard and make it available to anyone through an url. I am wondering how could I do that without requiring to login in Grafana and hiding the side bars and dashboard selection menu. I just want to allow accessing to view a dashboard from a website. I have read something about view and kiosk mode but theyr were old posts so I do not have clear if there is anything newer.
Do I need to create an iframe? I would like to avoid programming a frontend.
Thanks in advance.
if you are running self-hosted grafana, then you could get most of what you want by configuring anonymous access. This isn’t possible on Grafana cloud.
If you wanted to hide the sidebars and all that, then you’re probably looking more at an iframe / frontend development solution
