Docker, grafana/grafana:9.4.3-ubuntu.
- What are you trying to achieve?
Grant a user Admin privileges on a given team via the API.
- How are you trying to achieve it?
The swagger docs mention the following API Call that “should” work.
curl -X PUT -u "admin:admin" -d '{ "permission": 4 }' http://grafana.staged-by-discourse.com/api/teams/9/members/2
That responds back with a:
{"message":"bad request data","traceID":""}
I also tried to invoke the same call as the UI does
curl -X PATCH -u "admin:admin" -d '{"role":"Admin"}' http://grafana.staged-by-discourse.com/api/org/users/5
The traceID, I assume is something the UI generates and is an internal API only intended to be called from the UI. How would one grant a team member admin permission via the API? Is that not supported?
- What happened?
Error response mentioned above is returned.
The user be granted admin privileges for the given team.
- Can you copy/paste the configuration(s) that you are having problems with?
N/A
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Not using the UI, so no.
- Did you follow any online instructions? If so, what is the URL?
NA
