Grafana cloud -
Get the list of rules, both grafana as well as loki managed rules. -
loki/api/v1/rules - gives loki managed rules
api/ruler/grafana/api/v1/rules - gives grafana managed rules
looking for an api which can give all rules, be it grafana or loki managed.
Problem with getting it separately is loki doesnt support the same api key as grafana, so you need 2 set of credentials, one for grafana and one for loki.
What happened?
The above apis work fine, looking a way to get the combined list from a single api -
Cant find a single api -
