Any doc about how to setup Loki as clsuter?
Hi All,
Are there any doc about how to setup Loki as cluster? Any example?
The architecture overview is pretty comprehensive on how it should be setup, from there it’s a case of reading through Query Frontend | Grafana Labs and Examples | Grafana Labs to make sure that you’re using the correct config flags.
I’ve not seen a walkthrough, but hopefully those three links are enough to get you going in the right direction!
Thanks for your reply.
