Alloy snmp integrations
Anyone using Alloy with SNMP Exporter that can offer some help here.
So I have been using SNMP Exporter for ‘if_mib’ network switch information against our Cisco switches, it’s perfect. Recently I added a new module (in the generator.yml) to walk against these same switches for CPU and Memory this time, like this below and generated a new snmp.yml:
  cisco_v2:
    version: 2
    community: public
modules:
  # Default IF-MIB interfaces table with ifIndex.
  if_mib:
    walk: [sysName, sysUpTime, interfaces, ifXTable]
    lookups:
      - source_indexes: [ifIndex]
        lookup: ifAlias
        # Uis OID to avoid conflict with PaloAlto PAN-COMMON-MIB.
        lookup: 1.3.6.1.2.1.2.2.1.2 # ifDescr
        # Use OID to avoid conflict with Netscaler NS-ROOT-MIB.
        lookup: 1.3.6.1.2.1.31.1.1.1.1 # ifName
    overrides:
      ifAlias:
        ignore: true # Lookup metric
      ifDescr:
      ifName:
      ifType:
        type: EnumAsInfo
      sysName:
#       ignore: true
        type: DisplayString
  cisco_metrics:
    walk:
    - cpmCPUTotalTable
    - ciscoMemoryPoolTable
The problem I have is how I can’t use this new module called ‘cisco_metrics’ against the same switches. I use Alloy you see like this below. It looks for a switches.json file currently so it uses the ‘if_mib’ module only:
Here is part of switch.json:
    "labels": {
      "auth": "cisco_v2",
      "module": "if_mib",
      "name": "E06-SW1"
    "targets": [
      "10.10.5.6"
    "labels": {
      "auth": "cisco_v2",
      "module": "if_mib",
      "name": "E06-SW2"
    "targets": [
      "10.10.5.7"
You can see the module ‘if_mib’ I scrape. I don’t think I can add in another module here like ‘cisco_metrics’?
Here is my docker compose section for Alloy:
alloy:
    image: grafana/alloy:latest
    volumes:
      - /opt/mydocker/exporter/config/config.alloy:/etc/alloy/config.alloy
      - /opt/mydocker/exporter/config/snmp.yml:/etc/snmp.yml
      - /opt/mydocker/exporter/config/switches.json:/etc/switches.json
Here is the config.alloy
discovery.file "integrations_snmp" {
  files = ["/etc/switches.json"]
prometheus.exporter.snmp "integrations_snmp" {
    config_file = "/etc/snmp.yml"
    targets = discovery.file.integrations_snmp.targets
discovery.relabel "integrations_snmp" {
    targets = prometheus.exporter.snmp.integrations_snmp.targets
    rule {
        source_labels = ["job"]
        regex         = "(^.*snmp)\\/(.*)"
        target_label  = "job_snmp"
    rule {
        target_label  = "snmp_target"
        replacement   = "$2"
    rule {
        source_labels = ["instance"]
        target_label  = "instance"
        replacement   = "cisco_snmp_agent"
prometheus.scrape "integrations_snmp" {
    scrape_timeout = "30s"
    targets        = discovery.relabel.integrations_snmp.output
    forward_to     = [prometheus.remote_write.integrations_snmp.receiver]
    job_name       = "integrations/snmp"
    clustering {
        enabled = true
prometheus.remote_write "integrations_snmp" {
    endpoint {
        url = "http://10.11.5.2:9090/api/v1/write"
        queue_config { }
        metadata_config { }
As you can see it also points to switches.json and snmp.yml
I’m probably over thinking how to solve it. Can I combine the module section to include ‘if_mib’ and ‘cisco_metrics’ instead? If so how would that be formatted to include both?
Or
Use the 1 snmp.yml with 2 module sections and use a switches2.yml with the “cisco_switches” module in there, then add this new file to Alloy in docker compose and create a new section within config.alloy?
Thanks
Sorry, I dont know the answer to your question but perhaps you can help me:
how do you get Allow to fetch snmp data in the first place?
Do I need something additional (like snmpwalk) to actually fetch the data? Or should Alloy be doing that by itself?
Thanks
You can include “if_mib” under cisco_metrics to use both Cisco and IF-MIB modules together. Managing MIBs based on the vendor makes it easier to handle. I also faced issues when trying to use multiple modules as mentioned in the documentation, such as specifying “system,if_mib,mikrotik” as a comma-separated list. However, this approach didn’t work for me, so I ended up grouping all MIBs by vendor instead.
