Alloy prometheus.remote_write - How to set external_labels
Hi all,
I try to use alloy to send metrics to prometheus. That works.
But I want to set also labels like in the prometheus.job’s.
This is my config:
prometheus.remote_write “to_prometheus” {
endpoint {
url = “http://xxx.xxx.xxx.xxx:9090/api/v1/write” // Prometheus Remote Write API
external_labels = {
“instance” = [“address”],
“ciname” = constants.hostname,
“app” = “job”,
“job” = constants.hostname,
I want to have the content of
_address_ in the label instance
label job in label app
At the moment, only ciname and job are set (see last line),
I also tried it withe relabel, but this had no impact…
Thanks fo any hints.
Regards
Jürgen
Pretty sure external labels need to be static. Try setting the dynamic labels from prometheus.scrape or with prometheus.relable component.
I’ve this in my relabel:
And this is what I get:
No 1 is from a prometrheus-scrape-job.
And No 2 is from Alloy push …
And try have it like No 1.
But I found no way to get it … :frowning:
