Hi folks! I’ve got some issues with processing logs with Alloy before forwarding it to loki.
Here is an example log line I am concerned with right now:
{"level":"info","record_type":1,"card_present":true,"driver_present":false,"team":false,"work_type":0,"timestamp":"2024-09-23T00:00:00Z","time":"2025-01-10T17:45:45+01:00"}
The logger I am using is zerolog
Here is the alloy config:
local.file_match "tacho_json" {
path_targets = [
{__path__ = "/tmp/tacho.json"},
loki.source.file "tacho_json" {
targets = local.file_match.tacho_json.targets
forward_to = [loki.process.parse_json.receiver]
loki.process "parse_json" {
forward_to = [loki.write.default.receiver]
stage.match {
selector = "{record_type=\"1\"}"
stage.json {
expressions = {timestamp = "", work_type = "", record_type = "", drive_present = "", card_present = "", team = ""}
stage.timestamp {
source = "timestamp"
format = "RFC3339"
loki.write "default" {
endpoint {
url = "http://loki-gateway.o11y/loki/api/v1/push"
headers = {
"X-Scope-OrgID" = "1",
From my understanding – loki should rewrite the original timestamp for the timestamp in the JSON, yet it seems to completely ignore this pipeline stage.
It’s my first time setting up Alloy and Loki, so I might have missed something. But as of right now I am utterly confused ![]()
Can someone please help me understand?
