The k6’s GRPC client currently does not support using discardUnknownFields param in the GRPC client which limits the user to intentionally ignore unknown fields during the protobuf serialization process.
There are use-cases where it’d enable working with JSON request data that contains fields not present in the proto definition, such as extension fields or newer schema additions.
I’ve raised an MR to add that param: feat(grpc): add discardUnknownFields param to invoke and stream by kumar1202 · Pull Request #5742 · grafana/k6 · GitHub
Please let me know if this makes sense. Thanks!
