Hey Folks,
Having a lot of trouble getting alerts to trigger at all, the end goal is to set it up so that if bandwidth goes above x to send a notification to a slack channel - the current rule is looking for a max anywhere below 350 which is 50 above the link capacity and in turn should always be true; However after 16 hours it has not triggered once.
I have:
- Saved the dashboard
- Tried a number of a different combinations that should always fire (and saved each time)
- The test alert button indicated that it should fire and change to the ‘alerting state’
- The test notification button successfully posts to the slack channel
Version: Grafana v4.6.2 (commit: 8db5f08)
Datasource: InfluxDB
